Das Beast: My E30 track / street build
  • Elysian
    • 674
    #496
    Originally posted by dvallis
    Update. 3D printing was stupid expensive for some reason, so I'm getting a prototype of the solid steering link machined in 6061 aluminum. It's actually cheaper. Once we like the fit and finish, machine shop will give me a price for small production runs (10 units). Should be ready this week.
    If you need anything 3D printed shoot me a PM, I've got a Makerbot Replicator 2 that should do alright, and in a few months I'll have an SLA 3D printer. Also have a 50w laser cutter, and a small CNC router, if you need wooden templates for anything.
    • dvallis
      • Oct 2015
      • 1474
      #497
      I'll DEFINITELY take you up on that. Need to print a prototype case for the DasBeast Temp Gauge (see this thread).
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #498
        Brakes!
        Last bits of Massive Lee's kit arrived. These are hats for 1.25" x 11.75" rotors.
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1474
          #499
          Suspension Refresh
          Anyone looking for a complete suspension refresh parts list, here is what I am doing:
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            #500
            Das Beast Solid Steering Linkage
            Good idea for solid steering linkage. HOWEVER, R3v user feedback and some research revealed that U-joints need to be in phase. Otherwise steering might slightly bind.
            Notice U-joints are not in phase.
            Ugly rubber E30 OEM linkage. U-joints in phase
            New part in design. See For Sale thread.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              #501
              After some research, here is a small education on kill switches.
              My single pole setup would have potentially fried things when the ignition was cut, but alternator still being driven as the engine runs down. When opened, this six pole switch cuts power on the main battery cable and engine harness relays. At the same time, it connects a bleed resistor from the alternator to ground. Resistor provides a load dump while the alternator spins down.
              2002 E39 M5
              • totheredline
                • Jun 2013
                • 762
                #502
                Wow. Good stuff here. Awesome build
                Sent from my XT1585 using Tapatalk
                = Heidi 1988 325 -> 335i. 7200rpm built M30
                • 2mAn
                  Señior Mod
                  • 21038
                  #503
                  Its been bugging me.... it should be Das Biest
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • dvallis
                    • Oct 2015
                    • 1474
                    #504
                    My blog. My name. :devil:
                    2002 E39 M5
                    • sonomabimmers
                      • Dec 2015
                      • 802
                      #505
                      That linkage looks killer and for a good price. I'll keep that in mind. E30 shopping at the moment you being local elbow as well.
                      i love bmws
                      • sonomabimmers
                        • Dec 2015
                        • 802
                        #506
                        Helps *
                        i love bmws
                        • dvallis
                          • Oct 2015
                          • 1474
                          #507
                          Suspension removal progressing well. Everything is coming off. Will be pulling both sub-frames and adding reinforcement tabs.
                          Chassis is so stiff with the cage that it was completely flat on 3 jack stands. :devil: Paint job is really starting to grow on me. It's nice.
                          +1 for ECS Tuning. Control arms and tie rods arrived within a day, no extra charge for Saturday delivery.
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            #508
                            Skinny 12mm rear sway bar removed
                            Front subframe out. Will be reinforcing around motor mounts.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #509
                              Another shot of the front suspension dropped.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #510
                                More suspension removal
                                Rob is still getting Medieval on the rear suspension. Everything is out except the subframe and that will be gone soon.
                                Rear wheel hub getting taken apart
                                Parking brakes look Ok. Not a lot of wear on pads.
                                Will probably replace the CV boots and repack wheel bearings .. while we're there
                                Looking pretty empty under there
                                2002 E39 M5
