Well, we evidently goofed up a bit on the alternator. I had in my head it was just power and ground but obviously didn't check the ETM.
John, talk to me more about the alternator:
1) If just connected the 1.5 Blue wire to battery 12V on the starter, this would energize the field coil whenever our cutoff switch was closed, and kill it when open. Should eliminate the need for a diode, right?
2) If not, you're suggesting powering the 1.5 Blue field coil wire as a relay load, correct? And having a blocking diode on that?
Like this:
Like this:
