Updated 1/30/20
Installing this google Chrome plugin makes all photos in the build visible.
https://chrome.google.com/webstore/d...bifiaedg?hl=en
The extension below no longer works
https://chrome.google.com/webstore/d...flicjjgj?hl=en
This project started by accident. Out of the blue my wife said "You're a lot happier when you've got a race car. Why don't you go look for one". Knew I married the right girl ;-)
I've always been partial to E30s. To me they are more of a "driving machine" than post Bangle BMWs. A street / track E30 sounded like a lot of fun, so why not build one? Yeah, yeah, I know. Building race cars is expensive. Why not just stand in your garage and tear up $100 bills? Alright, goal for this project is a cost effective E30 track rat that is also street legal. It will eventually an M20 turbo.
After a ton of looking I found a clean, straight, rust free 325is with a good motor and so-so interior. Not bad for 1000ish dollars.
Ultimate goal is turn it into something resembling an E30 DTM. Yeah, yeah, I know you can spend $20K on a built race engine. That's not the point. This is a hobby. I'll have fun slowly turning it into a track car as budget permits.
3/2022 New Aero
3/2020
FINAL BUILD SPECS
1987 BMW 325i "E30"
2.8L turbo stroker
Built to NASA Super Touring and German Touring Sedan class specs
M20 Bottom End
M20B25 inline 6 base block
Stroked to 2.8L with M52B28 crank
Forged JE pistons 10:1 CR, custom valve pockets
Forged 4340 135mm Molnar rods + ARP2000 bolts
ARP crank studs and head studs
MLS head gasket 0.70"
Piston/rods/wrist pin sets balanced to 0.5 gram
Gapless top rings
New main & rod bearings
Custom 10QT baffled oil pan
Compression ratio ~10:1
M20 Top End
Stock BMW 885 head
Ported and polished
Schrick 190 lb valve springs
Schrick turbo cam 284/272
---lift 11.4 mm intake / 11.0 mm exhaust
---EO -246, IO -32, EC 26, IC 252 deg
---Intake / Exhaust overlap 58 deg
Ireland Engineering HD rockers
Stainless valves
Nuke adjustable cam gear
Kevlar timing belt
Turbo
Garrett GT3076R
Turbine: 0.63 A/R, T4 inlet, 3" v-band outlet
Compressor: 0.60 A/R 2" outlet
Ball bearing
Oil / Water cooled
Precision 46mm waste gate
Intake
K&N 4" x 6" tapered intake filter
Custom intake air box
3" charge piping
2.5" x 27" intercooler
Custom aluminum intake manifold and throttle body
Exhaust
Ceramic coated Rapid Spool Industries T4 turbo manifold
3" 16 gauge 409 stainless mandrel bent down tube and exhaust
Borla 40085 XR-1 resonator, round, 3" I/O, 304SS
Borla 40943 XR-1 muffler, oval, 3" I/O, 304SS
ECU / Ignition / Electronics
Megasquirt MSPNP Gen2 using "known good" turbo base tune
Using Tunerstudio and Megalog viewer
Wasted spark ignition
Delphi GN1023 ignition coils x 3
---Max Dwell 3.4ms
NGK BPR7ES 5534 plugs, 5K ohm, gap 0.031"
LC-2 wideband O2 controller
Bosch 17323 wideband O2 sensor
4 bar MAP sensor
IAT sensor
Throttle position sensor
AIM data acquisition system
Custom wiring harness
Custom lightweight dash
Fueling
Return fuel system
Fuel safe 15 gal cell
1 gallon swirl tank
Carter 100 gph lift pump
Bosch 044 275 gph high pressure pump
8AN braided SS fuel lines
Aluminum hard lines, cell to engine bay
Nuke billet fuel rail, 3/4" UNF
Aeromotive boost referenced fuel pressure regulator
Siemens Deka 60 lb PNP injectors
---static Flow Rate (GAS): 62.7 lb/hr = 646 cc/min = 474 g/min
---Dynamic Flow Rate 2.5ms PW @ 100Hz (GAS): 20.2mg/pulse
---Coil Resistance: 12 Ohms
---Gain: 0.11ms/mg
---Offset: 0.055ms
---Turn on time @ 14VDC: 1.14ms
---Turn off time: 0.85ms @ 600KPa
---Factory Tollerance: +/-6 %
Aux Mechanical and Electrical
JEGS double pass racing radiator
Aluminum coolant expansion tank
Valve cover breather and oil catch can
5-3/4" LED headlights
LED side markers, turn & tail lights
Chassis and Running Gear
Cage : 1.75" x 0.120 DOM 8 point pickup
Transmission : G260
Diff : 3.73 LSD
Clutch : Clutch Masters FX400
Pedal Box: Tilton 72-608
Brake Master Cylinders (F/R): Tilton 74-625U, 5/8"
Clutch Master Cylinder: Tilton 74-750U, 3/4"
Remote bias adjuster: Tilton 72-509
Front Brakes: Massive Lee 300 x 32 kit, Rotor 11.75" x 1.25" Hawk DTC HR8000L/HR8000R, Caliper Wilwood 120-11133, 4 piston 1.625"
Rear Brakes: Massive Lee 300 x 32 kit, Rotor 11.75" x 1.25" Hawk DTC HR8000L/HR8000R, Caliper Wilwood 120-11127, 4 piston 1.25"
Wheels: STR 518 17x9 4x100/114.3 73.1 hub ET22
Tires: 245/40/17
Z3 steering rack 32131092031 2.7 turns to lock
Machined aluminum steering knuckle
Ground Control adjustable camber/caster plates
Ground Control coil over adjusters on reinforced stock struts
Front springs Eibach 0600.250.0400 ( 6" length, 2.5" ID, 400 lb/in)
Rear springs Eibach 0500.225.0650 (5" length, 2.25" ID, 650 lb/in)
Ireland Engineering adjustable 25mm front / 22 mm rear sway bar
Body
Sunroof delete
BMW OEM 325is air dam
DTMFiberWerkz E30 rivet-on front and rear flares
DTMFiberWerkz E30 BRYTN Style Side Skirts
9Lives Racing 65" Wing
Ireland Engineering fiberglass hood
E30 late model plastic bumpers
Custom lexan side and rear windows
Custom aluminum diffuser
Hood vents
Updated 1/30/20
3/2022 New Aero
3/2020
FINAL BUILD SPECS
1987 BMW 325i "E30"
2.8L turbo stroker
M20 Bottom End
Gapless top rings
M20 Top End
Stock BMW 885 head
Ported and polished
Stainless valves
Kevlar timing belt
Turbo
Garrett GT3076R
Ball bearing
Oil / Water cooled
Intake
3" charge piping
Exhaust
---Max Dwell 3.4ms
4 bar MAP sensor
IAT sensor
Fueling
Return fuel system
1 gallon swirl tank
---Gain: 0.11ms/mg
---Offset: 0.055ms
Transmission : G260
Diff : 3.73 LSD
Tires: 245/40/17
Body
Sunroof delete
Hood vents
