Different valve clearance for cam?
  • 89325iturbo
    • Mar 2004
    • 723
    I put a 274 cam in my car. When doing a valve adjustment, should I stick with the stock specs?
  • ahlem
    • 369
    Yes, unless your cam manufacturer says differently.
    • digger
      • Nov 2005
      • 6194
      what did the cam card say?
      • 89325iturbo
        • Mar 2004
        • 723
        Didn't come with a cam card from bimmerheads. There was no mention of adjusting any differently in there notes with the cam. So I assume its stock settings, but was curious if anyone has set them different based on the cam they use.
        • digger
          • Nov 2005
          • 6194
          ask them for a cam card, you should get a cam card with an aftermarket cam. you want to know what you're running and how it is supposed to be installed.
          • 89325iturbo
            • Mar 2004
            • 723
            It's a regrind 274 split 415 lift.
            • Reichart12
              • Aug 2012
              • 2165
              Interested in this too. I got a 284 from them in a head already and their basic head install paper mentioned stock gap (but no mention of instructions if using a larger cam).
              Instagram: Reichart12
              • digger
                • Nov 2005
                • 6194
                Mostly likely they just install as per stock cam but advertised duration and peak lift tell only part of the story of what you should want to know when choosing and installing a cam.
