Valve cover gasket leak after changing valve cover...
  • E30_Narek
    • Sep 2014
    • 398
    I changed my valve cover gasket about a month ago and I torqued it down the right amount and with the correct pattern but now it's leaking even worse. I went back to tighten it a little bit more and that didn't help at all. I know it's from the valve cover because the area around and under it has started to become oily, plus those cardboard things above the spark plugs (which are right under the valve cover) get covered in oil every time after a drive. What should I do?
  • jeffnhiscars
    • Jun 2011
    • 6011
    Did you replace the rocker end plugs
    Alice the Time Capsule
    • E30_Narek
      • Sep 2014
      • 398
      Nope
      • bmwstudent
        • Sep 2011
        • 1364
        get another gasket and end plugs and try again
        • E30_Narek
          • Sep 2014
          • 398
          Didn't know I had to change end plugs with the gasket haha, I'll try it again then.
          • bmwstudent
            • Sep 2011
            • 1364
            when you first install them they will be a couple mm above the sealing surface. They squish to fit and seal. Once they are aged they become hard and don't seal as well because they aren't really squished down.
            • efficient
              • Feb 2012
              • 3312
              Rtv or any gasket sealer shouldn't be used on any of the corners?
              • abit
                • Jul 2011
                • 423
                I use a bit of victor reinz grey sealer, on end plugs and also on gasket both sides, just to be sure :D :)
                http://instagram.com/mundieriss
                my 88' m20b30 HERE!
                • E30_Narek
                  • Sep 2014
                  • 398
                  The gasket had that red trim throughout the middle of its edges. I think that's the sealer.
                  • whodwho
                    • Jun 2008
                    • 1547
                    No sealer and the lip of the rocker plug goes on the inside of the head next to the shaft, I have seen them the outside a few times!!
                    My M20 Frankenbuild(s)
                    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
