Cracked head, gasket or both?
  • JeLani
    • Aug 2015
    • 1552
    This obviously explains alot
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
  • 101
    • Jul 2011
    • 764
    I don't think you'll be able to tell until the head is removed.
    What happened exactly?
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • JeLani
      • Aug 2015
      • 1552
      It leaks already, from oil pan and im 100% sure it is from there because the gasket looks bad. And yesterday i was fooling around trying to re-bleed the system so the rad could fill back up and discovered this. Coolant mixing with the oil looks like but not %100 sure on that
      1998 e36 328ic/5 -
      1967 2002 parts car
      1994 318iS junked.
      • modernist
        • Apr 2014
        • 283
        Eek! Time to pull the head bud. Whatever that is it shouldn't be in the oil
        1986 327i
        transaction feedback
        DIY thing
        meh
        • TobyB
          • 5296
          Not just yet- there's no brown milky goo. It's together, but it usually emulsifies in the engine.
          If it were mine, I'd get the cooling system properly bled, and see how it went.
          Pressure test the cooling system, do the sniff test on the oil, yes, drive it not far
          from home, yes, but panic? Not yet.
          You may get lucky and that's just from the bleeding. It can sometimes sneak quite
          a lot out and you miss it.
          Optimistically,
          t
          • JeLani
            • Aug 2015
            • 1552
            Optimistically,
            It may be from the bleeding since i see the milky brown stuff in the coolant reservior
            t
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
            • modernist
              • Apr 2014
              • 283
              Touché.
              I guess check the dipstick and oil cap for milkshake/mayonnaise
              1986 327i
              DIY thing
              meh
