Driving w/ blown head gasket
  • e30_vt
    • Dec 2015
    • 60
    Long story short. Bought a car from a mechanic. Mechanic turns out to be shady because he washed down engine bay to hide blown head gasket. Now I am stuck in Connecticut and need to drive it back to Vermont.
    The car smokes a little. Upon driving it around it does not overheat. Visible oil leak under exhaust manifold. I can't tell if the oil or coolant is milky because shady mechanic just did an oil change and topped off the coolant. Oil leak seems to be small.
    My question is should I risk driving 200 miles on the highway back home or am I SOL.
    Before anyone says it....Yes, I am an idiot for being tricked.
    Thanks for any help in advanced.
    @e30vt
  • sublimation
    • Jul 2013
    • 155
    External head gasket leak isn't the 'traditional' blown head gasket. If it isn't using any coolant and the oil is clean, then you may make it. However, you should stop every 50 miles or so to ensure the condition is not getting worse
    • ak-
      • 12422
      I'd drive it. It's an E30 after all.
      Regardless, you're going to have to do the HG if it is indeed a goner.
      Worst case scenario is you crack the head. Just keep an eye on the temp. gauge and shut it off when it gets near the 3/4ths mark considering these things aren't the most accurate forms of measurement from MY experience.
      A used head is cheap. A rebuilt one from a shop also won't break the bank.
      A newly rebuilt one with all the bells and whistles will run you ~$1000 from our very own BimmerHeads on this site, which I recommend!
      GL! Update us.
      1991 325iS turbo
      • noid
        • 1537
        200 miles is nothing, if its overheating throw the heater on high (fan and heat), and keep an eye on the temps like mentioned above.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • e30_vt
          • Dec 2015
          • 60
          Thank you all for your responses and tips.
          A HG swap is definitely in order once I get back. I will update you all once I get back.
          @e30vt
          • Seawolf
            • Feb 2015
            • 270
            If you're taking I91 northbound and get stranded for any reason ping me a PM, I'm near Springfield western Mass.
            I know those old/new car white knuckle drives all too well.
            • turbo55
              • Jul 2014
              • 223
              The oil return passages on the exhaust side are on the edge of the gasket. You could have a HG that's leaking oil but not mixing with coolant (ask me how I know) and therefore safe to drive as long as you keep the oil level topped up.
              • e30_vt
                • Dec 2015
                • 60
                That is very kind of you. Thank you!
                I ended up making it home. It didn't overheat thankfully but it was shaking above 65mph. The steering wheel held steady and the car didn't pull to ether side. I wonder how much of the shaking was due to the soft top.
                Tomorrow I am spending a few hours diagnosing the whole car to see what needs to be replaced.
                @e30vt
                • Seawolf
                  • Feb 2015
                  • 270
                  Woohooo Christmas I spy....my fave game....
                  Cam cover gasket
                  FPR vacuum line
                  Timing belt
                  Tensioner
                  Water pump
                  Tensioner spring & pin
                  Exhaust manifold heatshields
                  ....let the fun begin :-)
                  • turbo55
                    • Jul 2014
                    • 223
                    Is the #1 spark plug lead plugged in? Looks long compared to the others
                    • TobyB
                      • 5297
                      Timing belt!
                      t
                      • e30_vt
                        • Dec 2015
                        • 60
                        Hahaha. Keep it going!
                        The timing belt and water pump have been done by the previous owner. Or so he says. I have proof that the clutch has been replaced.
                        Other things in need of replacement:
                        1. drivers rear window switch or motor (window won't go down)
                        2. Rebuild the gauge cluster (left side won't light up).
                        3. Gas gauge works intermittently
                        4. Interior is in rough shape.
                        5. Trunk shock is toast.
                        6. Windshield washer fluid not hooked up.
                        Tomorrow I find out more once I actually take the time to diagnose it.
                        Buy an E30 they said. It will be fun they said. Hahaha
                        @e30vt
                        • e30_vt
                          • Dec 2015
                          • 60
                          Not sure. I'll have to check it out tomorrow and get back to you.
                          @e30vt
                          • noid
                            • 1537
                            Thats the whole fun of an E30, you buy it rough, you make it nice. If it was nice from the start it wouldnt be nearly as fun.
                            • joecrotch
                              • Dec 2008
                              • 117
                              I had a vert that I bought like this once. I just re-torqued the head and drove it 500 miles with no leaks. That re-torque ended up lasting me 2 years with no issues. Its no replacement for a new HG but it will definitely work in a pinch!
                              Joe
