E30 M3 coolant expansion tank work with M20?
  • E30-Ellerman
    • Oct 2015
    • 212
    Hey there, sorry if this has been discussed just couldn't find it in search.
    Have a pre facelift E30 that I will be turbo'ing in the near future. Need to relocate the coolant reservoir tank and have a line on a cheap M3 coolant tank that mounts near the firewall on passenger side.
    Wondering if this tank will 1) bolt up easily in the battery tray area near the firewall on passenger side (where it bolts into the m3) and 2) if the hoses will work with the water pump and radiator (same size hosing?)
    Have others done this and I just can't find it in my searching?
    Thank you!
    2016 F-150
    1987 Royalblau 325es B25 turbocharged
    Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
  • reelizmpro
    • 9558
    I don't see why not as long as you extend the hoses since both tanks are on the same side of the engine. The M3 tank will just be farther away. I think the later style tank would be better though.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • E30-Ellerman
      • Oct 2015
      • 212
      Thanks man, same thing I was thinking, would get longer hoses and everything, would hide it away from the turbo and from an M3 engine bay, looks far enough away from the turbo exhaust housing to be fine.
      2016 F-150
      • reelizmpro
        • 9558
        Is it a top mount turbo? if so, the downpipe will be in the way of the coolant hose. With the late model setup it keeps the coolant hoses on the drivers side away from the heat.
        88 M3 - LACHSSILBER
        • E30-Ellerman
          • Oct 2015
          • 212
          Yes it will be a top mount turbo... thinking it may be easier to relocate stock one as it's smaller (oval/pill shaped one), only tough part is making brackets to mount in battery tray area..
          2016 F-150
          • AndrewBird
            The Mad Scientist
            • 11898
            I'd do this and swap to a late model system. All factory parts that are proven to work.
