m20 hesitates coming off idle and midrange but is not constant. Also occasionally throws a CEL. Do a stomp test and nothing shows( Im assuming because CEL isnt constant). I have replaced o2 sensor, smoke test for leaks, temperature sensor, new cap and rotor, plus wires, fuel pressure regulator, cleaned ICV Could it be injectors?
m20 hesitations
Tags: None
Check your tps and if you can trade afms with someone I'd try that.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
