Smog fail help
  • uhhrace
    • Feb 2016
    • 15
    Smog fail help
    Bought a 1986 325es this weekend and I'm trying to get it registered and on the road. I just failed the emissions test, here are my numbers
    So I've got a high NOx reading, and I also failed the fuel EVAP test. I've read that the engine running lean can cause high NOx readings, so I'm gonna start replacing vacuum lines first. Is there a way to test that the O2 sensor is reading correctly? Any advice from someone who's had these problems before? Thanks in advance.
  • Best_name_available
    • Jul 2014
    • 479
    1.Vacuum lines
    2.O2 sensor
    3.Make sure ignition is good
    4.Sea foam treatment
    My car failed the sniffer so I did all the things above and passed without a catalytic converter.
    Originally posted by Vokuhila
    I laughed, and then I serioused
    • htx_e30
      • Sep 2014
      • 132
      Damn.. So glad I live in a state now where I paid $7 for a 'classic car' inspection and just did a safety check and passed. Had this same nightmare before and did most of what member above me said & fixed the problem. Good luck!
      • abit
        • Jul 2011
        • 418
        just pour e85 fuel in your fuel tank and try again :devil:
        http://instagram.com/mundieriss
        my 88' m20b30 HERE!
