11:1 eta bottom end w/ 731 head 2.7i help
  • mackETAttack
    • Mar 2012
    • 53
    Hello everyone,
    I'm getting ready to do a 2.7i build with an euro eta bottom end that has the 11:1 compression pistons and a 731 head. So far i have the: engine(running w/ 175k), 731 head and throttle body.
    For now I would like to just bolt the head up and use my chipped 027 dme to get some more top end while I'm gathering parts but I have a few questions about this setup i'm hoping someone can help me out with.
    What intake manifold you guys would recommend the b23 or the b25?
    Can i use an eta head gasket?
    Will there be any issue with valve clearance?
    I do plan on rebuilding the engine soon and swapping to motronic 1.3 or MS but am waiting until car is not a DD anymore.
    Thanks for any help.
  • jeffnhiscars
    • Jun 2011
    • 6010
    The combustion chamber in the 731'is the same as the 200 so if you are using the stock valves the clearance should be the same although I have no knowledge about your HC pistons.
    I'll be using the b23 intake with my 731 (w+2 valves) so you should be fine with that and a b25 TB
    Alice the Time Capsule
    • mackETAttack
      • Mar 2012
      • 53
      Thanks, i didn't think clearance would be a problem i just haven't heard much about this combo.
      Are you doing any other work to the head?
      • jeffnhiscars
        • Jun 2011
        • 6010
        besides the over sized valaves, virtually everything has been replaced....springs, guides, 272 cam, decked, rockers refaced and I may replace th eccentrics just since they are the only part that is not new.
        • mackETAttack
          • Mar 2012
          • 53
          Sounds like you have a nice engine in the works. I checked out your threads and got a lot of info, thanks for that.
          How do you like it with the eta electronics?
          • jeffnhiscars
            • Jun 2011
            • 6010
            Glad you found it interesting.
            The head isn't installed yet. I'm 100% stock ETA for now except for an SSSquid chip
            • 5Toes
              • 9836
              Im watching this tread. I have a 11:1 eta block and 731 head on the bench. I want to do valve upgrade and a schrick cam in the head, stock bottom end, i intake manifold, and throttle body, chip tuned
              • jeffnhiscars
                • Jun 2011
                • 6010
                Start gathering your motronic parts. Took me a while to get decent parts at a decent price.
                • mackETAttack
                  • Mar 2012
                  • 53
                  I'll post updates as they come. I'm going to use the stock b23 cam, I intake and a 64mm neuspeed TB w/ spacer thats from the 80's. I also want to put larger valves and have it matched ported. I heard that MarkD has an e/i chip that lets you use the stock eta harness.
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    I got these back today from Delta Cams. They are the original b23 rockers only refaced and lightly polished.
                    • mackETAttack
                      • Mar 2012
                      • 53
                      those look nice!
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        Originally posted by mackETAttack
                        those look nice!
                        I'm pleased with them especially for 1/3 the cost of Febis
