m20b25 hose routing vs heater core
  • funcrew
    • Jun 2007
    • 1223
    There's 2 hoses that go to the heater core at the firewall:
    1. 3-way hose from the coolant reservoir
    2. single hose from the cylinder head near the firewall
    Which of these goes to the top connection on the heater core? I figure it matters because the HC valve wants pressure against it in a certain direction.
    Thanks in advance for your help!
    EDIT: 1991, and I'm eliminating the screwy coolant safety valve monstrosity thing that hangs in the middle of the hoses.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • digger
    • Nov 2005
    • 6072
    this help ?
    http://www.realoem.com/bmw/enUS/show...diagId=64_1720
    • funcrew
      • Jun 2007
      • 1223
      digger, I tried all the realoem diagrams, but it didn't clear things up. My hoses connect to the metal tubes from your link. Still appreciate the help though.
      -Dr. Paul Forrester
      • Seawolf
        • Feb 2015
        • 270
        Upper heater hose goes to the 3 way bitch hose.
        Lower heater hose goes to the back of the head.
        Had the same question when I changed out my hoses and junked the recall safety valve.
        Read this: http://www.r3vlimited.com/board/showthread.php?t=203038
        • funcrew
          • Jun 2007
          • 1223
          Sweet - Thanks!
          -Dr. Paul Forrester
