On the ETA fuel tank, are you referring to the lines/connections where the fuel sender also is? I only have 1 access door under my rear seat (on passenger side). Interestingly all connections do look good and dry. Are there any connections made on the driver's side top of the tank? This is where the fuel appears to be leaking from. Do those connections run directly from the passenger side top of fuel tank to the inline fuel pump next to the tank on the driver's side? If those hoses are just running straight from point to point, I might just replace them 1 at a time until the leak is gone.
I do have a replacement CPS. It's new; though when I had initially tried it before, the car didn't want to start. Checking the resistance on the new sensor, it read about 860 OHMs. My currently OEM one read 560 OHMs. I contacted the company that sells it and had them do a resistance check on one off the shelf; it read the same at 860 OHMs. Were there different front mounted crank sensors? Here is the link to the one I bought http://www.eeuroparts.com/Parts/1094...r-12141720852/ . Anyone have any experience with this particular replacement part? I see this one for sale on many parts websites I tend to frequent for this particular car.
Lastly, since I let the car sit for about 5 days untouched, I decided to crank it over and let it run. I noticed the FPR is slightly back feeding some fuel. Really only seems to do it when the car is shut off though? This could be pointing to a bad FRP and I should probably just replace it. Any brand recommendations? The Bosch one seems a little too expensive for my taste. RockAuto has one for less then half, http://www.rockauto.com/en/moreinfo....011698&jsn=359 . Any thoughts on this?
