Stroker Fitup Question
  • boogle2
    • Dec 2014
    • 115
    I have an iX block, with an eta 81mm crank. I am planning on going turbo.
    Was curious, just put in my order with VAC for rods and pistons, and they recommended going with a 135mm rod over 130.
    It was my understanding that I needed a 130mm rod to fit in the block correctly? Or since they are custom CP pistons, they will change them to fit with the 135mm rods properly? let me know if I am understanding that correctly.
    Thanks
    2011 335i xDrive Msport - sold
    2002 M5
    '88 325ix turbo build :D
  • digger
    • Nov 2005
    • 6216
    They will change the compression height of piston to suit the longer rod since you're getting custom Pistons
    • boogle2
      • Dec 2014
      • 115
      Perfect thanks.
      2002 M5
