Fuel Filter Soft Lines
  • sampayne
    • Apr 2014
    • 396
    I'm replacing my fuel filter soon, and obviously the soft lines around it have seen better days. I'm pretty sure you can buy specific made hoses that have the tight radius bends, but I happen to have some straight fuel line. Has anyone replaced these lines before normal hose? Any trouble with kinking ect. ? Thanks
    Originally posted by 2mAn
    The BMW V6 is the best
  • jeffnhiscars
    • Jun 2011
    • 6011
    Just leave enough length so the radius is not too small and make sure it won't rub against anything. I'd also suggest you get the proper hose soon as you really don't want to take chances with fuel lines
    Alice the Time Capsule
    • sampayne
      • Apr 2014
      • 396
      I'm not really in any rush, none of the lines are leaking or anything like that. Would you suggest I just wait until I can order the proper hose? Thanks
      • jeffnhiscars
        • Jun 2011
        • 6011
        I go by the principal of do it right do it once so yes order the hoses if time is not an issue. I think I paid $6 for the little U shaped ose and at least on some models the fuel filter bracket has 3 rubber mounts that you should check. You def don't want one of those to let go when you are driving.
        • sampayne
          • Apr 2014
          • 396
          Very true, very true. I'll look into getting those hoses soon. Thanks
