Using 22lb injectors at 2.5 bar
  • low808
    • Nov 2013
    • 661
    A few of my stock injectors are bad above 17ohms. Can I use 22lb injectors at 2.5 bars or even lower at 2 bars since I have an abjustable fpr.
    • 34844
    it would technically work, but the fuel will not atomize as well at lower pressures. That's why newer port injected cars run at 5 bar instead of 2.5-3.
    if it's temporary while you get proper injectors it could work though.
