Fuel injector electrical connection... Help!
  • Mook613
    • Apr 2016
    • 232
    In the process of replacing fuel injectors.
    I am trying to disconnect the main wire at the circular connection on drivers side.
    The bottom part will unscrew no problem, but I can't figure out how to take the top part out.
    Help!
  • Seawolf
    • Feb 2015
    • 270
    Do you mean the C191 plug and socket under the intake manifold ?
    If so, it just screws open but they can get sticky when grit gets into the plastic thread. Use 2 pairs of channel locks to open it if you need to - be careful not to pull the wiring around, they have a habit of breaking off from the plug pins if they're corroded.
    • Mook613
      • Apr 2016
      • 232
      Yes, that's the plug.
      There are two parts to this plug, the part coming from the injector rail, and the part going to the Motronic.
      I can unscrew the bottom part, which goes to the Motronic, and that hangs down completely disconnected.
      What remains is the wire coming from the injector rail. It is held into a bracket and I can't figure out how to remove it from the bracket.
      • Mook613
        • Apr 2016
        • 232
        Anybody? Could really use a hand.
        • PKile
          • Apr 2016
          • 184
          My guess is there is a plastic ring collar that unscrews to release the plug from the bracket...it is similar in configuration to the plug to the oxygen sensor
          • redlightpete
            • Mar 2012
            • 266
            Yes there's a plastic ring under the mounting bracket that you need to unscrew. You may want to gently use some slip joint pliers.
            • wilholl
              • May 2012
              • 518
              Emphasis on "Gently"!!!!
              Not fun to fix when the wires break at the pins
              1988 325 non-letter Seta "Bronzit"
              1991 325ic "Laguna Green" (Sold)
              1993 325i "Laguna Green/Silver" (Sold)
              1998 528i "Artic Silver" m-sport(totalled by drunk driver)
              2000 528i Titansilber/gray m-sport
              2000 528i Titansilber/black m-sport(sold)
              2001 525i Anthracite m-sport(sold)
              2013 750i Black/Black m-sport "Beast"
              • chemprof
                • Apr 2016
                • 25
                THANK YOU! I was struggling with getting the electrical rail out of the way and couldn't figure out how to get if off that bracket. Seems so obvious after its done. BTW, I found accessing the ring from underneath, from the front easiest. Mine unscrewed with little force.
