ALMOST BLEW UP ENGINE, but how!?
  • Jdub
    • Mar 2016
    • 79
    SOMEHOW, this tiny little piece got caught in between my timing belt cover, and my timing belt. The result was my
    My question is: Do those tiny little nicks on the camshaft gear look like something that would force me to have to get a new camshaft gear? They aren't sharp or anything.
    I'd rather get a new $16 belt and call it a day rather than wait for that special order part which is going to take about a week before it even ships!
    (this is a view of the side, there is no apparent disfiguration)
  • Matt-B
    The Waffler
    • 3856
    I dont see any pictures
    • Jdub
      • Mar 2016
      • 79
      Thats weird, hopefully those links will work instead of the actual pictures?
      • Lodsin
        • Sep 2006
        • 734
        • Jdub
          • Mar 2016
          • 79
          Thank you
          • AndrewBird
            The Mad Scientist
            • 11898
            I wouldn't worry about the nicks. Just hit them with a bit of sandpaper to remove any sharp edges and it will be fine.
            • george graves
              • 19996
              ^good idea.
              • Cabriolet
                • 9620
                there should be a rubber cover over the back upper cover. if you are missing that, FOD can get in and cause this to happen.
                Much wow
                I hate 4 doors
                • bangn
                  • Sep 2011
                  • 760
                  looks like a dowel
                  Boris - 89 E30 325i
                  84- E30 323i
                  • RobDog
                    • Aug 2012
                    • 188
                    Its Hard to tell by the pic, but it looks like you have the older recalled stamped camshaft sprocket. If you take off the plastic cover behind the rotor and take another pic we will be able to tell you if it is or not. If it is than I would replace the sprocket.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      That's one of the cast ones, not stamped. Stamped ones look like this:
                      Note the gaps between the teeth.
                      • gath
                        • 577
                        Originally posted by Lodsin
                        By the look of that last picture, that piece looks like one of the dowels that hold the engine hoist bracket. It seems like you are missing it on the cylinder head.
                        • Jdub
                          • Mar 2016
                          • 79
                          I think you're right, is that something I need to replace, or am I ok with leaving that out for now?
                          ALSO: when the mark on the camshaft gear is lined up with the timing mark on the head, the timing mark on the lower timing apparatus, I forgot what it's called, is just barely off. Could this be causing the throttle response issues I have? How significant could this issue be for timing even if it's just very slightly off? If this is the issue can I just manually readjust it before putting back the timing belt? That's what I plan on doing as of now
                          • mbonder
                            • 2255
                            If it's only slightly off you shouldn't be having any noticeable issues. Just move the crank gear back into alignment and you should be good to go. Throttle response issues seem to point to something related to vacuum, not timing, but it's kind of hard to tell without actually hearing the engine run.
                            • djjerme
                              • 5082
                              As stated above, that looks like the locating dowel for the engine housing bracket and the front timing cover.
                              If the dowel came out (bolt back out, feel out) it's possible the timing cover slid down and was running against the timing belt. Replace the dowel, the bolt, the timing belt and torque that bolt to factory.
                              Sent from my 710C using Tapatalk
                              2016 Ford Flex
