ALMOST BLEW UP ENGINE, but how!?
  • uturn
    • Dec 2010
    • 1000
    Your distributor sits on that timing cover, without the engine hoist bracket, not sure if incorrect spacing will cause funny issues with contacts and the rotor.
    • 5Toes
      • 9836
      upgrade to the m20b25 forged cam gear while you are in there. also replace the cam seal. cheers
      • AndrewBird
        The Mad Scientist
        • 11898
        You definitely need the engine hoist bracket as it acts as a spacer for the timing cover.
        • Jdub
          • Mar 2016
          • 79
          I should have clarified. I meant leave out the dowel.
          **BUT, after I did the timing belt job today I turned it on and it idles fine. Only when I gave it a little gas did the belts start to scream and it shut off. I gave it some time and started it back up again and it idles totally fine, and when I give it gas it doesn't die. But, the belts still squeal like crazy. What could this be? I made sure not to tighten them that much. Maybe they're too lose??
          It also takes forever for it to turn over now too :(
          • Jdub
            • Mar 2016
            • 79
            UPDATE: I think I found out why I had issues getting it back up and running. Check out the damage on my crank position sensor. Got a new one otw.
            • Jdub
              • Mar 2016
              • 79
              Update pt. 2: I got my new CPS plugged in and the car runs great again. Still having issues with the poor throttle response but overall the car feels more responsive.
              I think my next step will be adjusting the throttle cable as I haven't done that yet and it seems pretty loose. Also dropping in some Lucas Oil Stabalizer to help with the slight ticking I am getting!
              • UgkNW*
                • Oct 2013
                • 259
                If This is true would the bolt on the right being stripped but still sitting in place cause any problems? That bolt o mm my head is stripped but as far as I can see doesn't seem to interfere with anything. That said my valves tick like crazy.
                Oh and done mean to thread jack thanks
                • Jdub
                  • Mar 2016
                  • 79
                  I have the same issue and I have been driving it daily with no issues at all. Also just took an 1800 mile road trip with it like that. Hope that helps
                  • Ether-D
                    • Sep 2011
                    • 2838
                    M20's tick when they are perfect. It's just what they do.
                    The injectors are very audible.
                    Originally posted by Andy.B
                    I was born on 3/25…
