i've seen people saying that they put a i intake on a e head. wouldent the diffrent port sizes create a flow proplem
i intake on e head?
The manifold is a direct bolt on...
the e manifold favors lower RPM and i manifold favors the higher RPM
The throttle body on the i is bigger and e is smaller.
Everything is a direct bolt on -
h0lmes
Ive got one with injectors and fuel rail that I can have shipped to your door for 80 bucks. Let me know if you are interested.Comment
the head is the same casting for the e and i head....welll 88 528e head and 325i head are the same minus holes for the cam journals. So theoretically you can take out the same material and come out the same.
If you have the bentley you can see the size of the port.
It would be pointless just to put on the intake as you wouldnt see any difference minus the bigger throttle body
I would just do the head swapComment
