Timing belt rubbing?
  • 2002tiiguy
    • Jul 2013
    • 467
    anyone ever have their timing belt rub on the timing cover? sounds like a belt chirp, not all the time but it annoys me when it happens.
  • 2002tiiguy
    • Jul 2013
    • 467
    nvm i finally found some answers, ill try throwing a new belt and tensioner on it and see if it goes away
    • downforce22
      • Aug 2009
      • 3192
      happened to me and grenaded my engine. it ended up being the oil pump drive gear bolt came loose and the belt was cocked to the side, wore a groove in the cover before finally skipping a tooth on the timing gear
      • 2002tiiguy
        • Jul 2013
        • 467
        lol sorry to hear that, thankfully mine only does it when the engine is cold and its not constant, once i get back from vacation ill swap it out
        • Garrick2007
          • Jun 2014
          • 59
          Wow I was just getting ready to post about this and seen yours. My car has been doing this for about 3 years now, I checked the forums then and found nothing, started randomly after a timing belt change. Only does it while cold and fades as the car warms up. After a year or 2 I did another belt change thinking maybe it was a bad tensioner or something. Put it back together and it retuned a few days later. So I'll say now that changing out your belt/tensioner probably won't fix the issue. Something somewhere is touching it or going out, Keep an eye on it because If will fray up the belt over time. Keep us posted on your findings though, in about a week or 2 I'm going to take another stab at it while doing a partial rebuild.
          Update: I think I see the posts about the tensioner. Guess it could be a possibility which is dumb because mines was brand new.
          • Garrick2007
            • Jun 2014
            • 59
            Here is a video so u guys can here it. https://drive.google.com/open?id=0B5...UVtWnprbWdyV3c
