Clutch removal
  • smooov
    • Jul 2009
    • 36
    Clutch removal
    Hey guys, I am having a hell of a time getting the top reverse torx bolt off of the bellhousing of my sETA. I have attacked this bolt from every angle with both shallow and deep socket reverse torx wrenches and I just cant seem to get it off. Any advise for a noob like me? The bolt in question has wrench on it in the photo and is right up next to the fire wall. http://imgur.com/a/M1KGN
  • packratbimmer
    • Dec 2009
    • 1335
    Get under the car with every extension, u-joint and wobble joint you have. Use as much 1/2" drive as you can. Tape the joints if you have to so they don't flop around. Use a breaker bar first. Getting it slid onto the bolt might require a friend.
    • smooov
      • Jul 2009
      • 36
      Do I need to remove the bolt just above it that goes into the firewall?
      • packratbimmer
        • Dec 2009
        • 1335
        Not sure what you mean
        • smooov
          • Jul 2009
          • 36
          I ended up dropping the rear of the drive train to make space to attack the bolt. I am working in my garage, so space is a bit of an issue (no lift) and I didnt have enough clearance from the ground to use the breaker bar. I could not get this thing to budge. I think that I am going to end up just pulling the whole drive train and work on the bolt once it is out of the car.
          • staysideways
            • Dec 2013
            • 373
            I loosened the motor mounts and jacked up the motor from the front so it gave it that tipping over behavior than went to harbor freight and bought 3 2.5 foot long extension and put it on a wobble head and cracked it off with a breaker bar.
            • smooov
              • Jul 2009
              • 36
              I ended up stripping the bolt out. I used every wobble, extension and ujoint that I had. Either way, I hammered the torx bit on there, but it just wouldn't crank. A new harbor freight just opened up in my town so I am going to head over and buy a few more extensions this weekend and see if I can make enough room to hit it with the long breaker bar. I will keep you guys updated.
              Thanks a million for talking me through this guys!
              • packratbimmer
                • Dec 2009
                • 1335
                Are you soaking it with PB Blaster?
                • smooov
                  • Jul 2009
                  • 36
                  Yes, I soaked it in penetrating juice a few times during the attack. I will soak it good tonight.
                  • packratbimmer
                    • Dec 2009
                    • 1335
                    Not WD40 I hope
                    • spdracrm3
                      • Sep 2009
                      • 959
                      Also if you can get in there smack the bolt head either directly with hammer or use a long steel rod /extension ,sometimes shocking the bolt will help loosen it
                      Sent from my SM-G360V using Tapatalk
                      Angus
                      88 E30M3 X2
                      89 325IX
                      92 R100GS/PD
                      • smooov
                        • Jul 2009
                        • 36
                        Not WD40 I hope
                        No way, I got some pb bolt penetrate
                        • squidrope
                          • Dec 2012
                          • 291
                          Put a torch to it
                          Heat helps
                          • smooov
                            • Jul 2009
                            • 36
                            It came apart today guys!
                            Discover topics like harry potter, and the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users like samesmile.
                            • staysideways
                              • Dec 2013
                              • 373
                              Nice. Did you end up getting the long extensions from harbor freight? They are awesome. I have the ones that lock so the socket doesn't stay on the bolt. Everyone needs at least 2
