Loose Cam Belt?
  • redlightpete
    • Mar 2012
    • 266
    Loose Cam Belt?
    Every time I've replaced an M20 cam belt (four times, I think) the old belt was flopping loose. Is this typical? It makes sense that with a fixed tensioner position, any wear or stretching will loosen the belt, but how much is acceptable? I do try to tighten the tensioner with the engine rotated to have max tension on the side opposite the tensioner.
  • wilholl
    • May 2012
    • 518
    Usually fairly loose if you use the twist method on install.
    I had one too tight once and it made a lot of noise.
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
