Hi guys, I did my research but cannot find what I'm looking for. I found out that the E34 535i harness is similar to the late E30 M20b25 harness. I even found out that people can use the M20b25 harness in a m30b35 swapped E30. (note: I completed my M30 swapped into an E30 in 2012.) Now I am looking to stroke the m20b27, why? because I have all the main parts just sitting around including a few M30b35 harnesses and ECUs.
My question is can I use the M30b35 harness and its' ECU on the M20 stroker? I'll be using 19 lbs injectors, and M30 AFM. Thanks
