V-belt sizes.
  • BaltimoreBimmer
    • Apr 2016
    • 307
    V-belt sizes.
    Doing the belts among other things. Ordered belts from pelican parts and now they seem to not fit. Went back online and apparently they have several sizes for each belt. So which ones are correct?
    I just bought a Conti tech belt package that was "compatible":
    10x965
    10x825
    13x810
    Can't even fit the alternator belt on with the adjusting rack removed....
    ok, finally ran across this thread: http://www.bimmerforums.com/forum/sh...-t-fit-88-325e
    looks like people are saying its a tough fit even with the unit as far in as it goes. I have to apparently 'roll' it on or get it sort of started and then turn the crank? Everyone says they 'bump' the engine to have it apply force to things such as getting this belt on, or removing the fan, or removing the crank bolt. That sounds extremely sketchy to me, so I will stick with hand turning
    ok. turns out you want to put it over the crank pulley LAST. this somehow makes it work perfectly, didn't have to even stretch it on. I feel silly now.
    Got a crowsfoot metric set + a 20-200 inch pound torque wrench today from harbor freight for 30 bucks. Hell yeah
  • digger
    • Nov 2005
    • 6194
    the A/C belt there are two lengths 810mm and 823mm. with alternator never had any issue (except with geared nuts) once it was loosened
