How do I remove these?
  • canyoncoolman
    • Jun 2016
    • 1
    So currently I'm working on removing the head of my e30 because the dude I bought my e30 from said it had a blown head gasket. This is my first time working on a bmw and I have been mostly using the internet for help. Right now I'm stuck. I don't now how to remove these things but I need them gone so I can remove the head. The Car is a 1989 325i
    First thing I'm stuck on is what I think to be the fuel line. Im not sure if it is but either way I have no idea on how to remove it. Image
    Second Is this black cap thing. I have no idea what it is but it looks to be electrical.
    Please help
  • efficient
    • Feb 2012
    • 3312
    1st picture underneath the intake manifold is for the injector harness. You hold the bottom base and turn it counterclockwise wise.
    The 2nd picture is a c101, it's use is for diagnostic port. Check engine scanner, resetting oil service light
    • downforce22
      • Aug 2009
      • 3193
      What he said^. Disconnect the c101 by unscrewing the bolt holding it to the intake.
      Are you sure the car has a bad headgasket, you don't sound too positive.
      • M_3_X
        • Jul 2016
        • 162
        Also make sure the timing belt is no due. 4years/60k miles for that.
        "If everything seems under control, you're just not going fast enough"
        -Mario Andretti.
        ___________________
        River City Bimmers BMW CCA
        2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
        2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
        1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
        • E30DriftMissile
          • Aug 2012
          • 301
          Stop. Download a e30 manual or look up the diy on pelican parts r3v or google it. Your engine is the m20b25. No sense in pulling it apart if your going to try and reverse engineer everything back together if you can't identify the basics of the harness/engine. It won't go back together right. Not knocking your hustle. But one 5hr session with a pie from your fav pizza joint will help you more then posting about which one is the fuel line [emoji1419][emoji848]
