Car try's to start as soon as I put the battery in with no key.
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Hey guys I've been putting my m20 back together and I've run into an issue. When I try and put the battery in the car it sparks and it sounds like the starter is kicking on. Is it possible the starter is wired wrong I took a picture I put both the thick red wire from the harness and the thick black wire from the fire wall on the big post is this right? Also I took a photo of the power block too I need to get this thing done so any help is appreciated
    88 325is Five Speed
    Lachssilber
    • Feb 2012
    • 3580
    so i went out and unhooked the two big wires and this time the battery at least didn't short I'm still really confused i thought both thick wires were supposed to go on the big post
    88 325is Five Speed
    Lachssilber
    • jeffnhiscars
      • Jun 2011
      • 6011
      With the wires off and the batt connected I'd check the polarity of each. Usually red and black are opposites.
      Alice the Time Capsule
        • Feb 2012
        • 3580
        Fixed it, power was arcing from the two big wires to the 8 mm wire, if this happens to you bend the two big wires forward a bit for clearance
        88 325is Five Speed
        Lachssilber
        • E30DriftMissile
          • Aug 2012
          • 301
          Great! I believe both big wires do go on the big post. That's how mine is too. What'd you end up doing with them?
            • Feb 2012
            • 3580
            Bending them slightly toward the front of the car seemed to work
            88 325is Five Speed
            Lachssilber
            • E30DriftMissile
              • Aug 2012
              • 301
              Ah gotcha so you left them on the same post
