Hi everyone, I swapped an M20B25 into my 2002 (woo hoo) and I'm trying to figure out why the motor won't fire. I've been through the ETM and bentley manuals trying to track down the problem - conducted just about every electrical test I could think of - I even went through a great article that BavAuto has on diagnosing no start issues.
Ok here's what I've done. I'm hoping someone can point out the obvious to me....
So a few things to note. Charcoal canister is deleted. Purge valve connector is not connected to anything. I'm assuming it's the purge valve connector....
I don't have a spare ECU to rule out the ECU.
ANY help is greatly appreciated.
_C
- Spliced 2002 harness into the M20 harness using the C101 connector for various connections (charge, fuel pump, oil pressure, ecu power, etc). It all appears correct....;)
- Test Fuel Pump direct to +12V - PASS
- Test fuel pump relay control - Jump pins on 36+2, ground pin 3 on motronic connector - PASS
- Test main relay control via motronic connector - PASS - relay clicks
- Main relay was suspect since voltage was present on 30 and 86, but not on 87 when key in START, so I replaced it.
- Test Fuel Pump Relay voltage between 85 and 86 with ignition on - FAILS
- fails on 12v test between pins 85/86 with ignition on
- Starter is working - engine tries to turn over, no firing.
- Spark test FAILS
- Fuel injector pulse FAILS
- Coil has power
- ECU is getting constant +12V from two pins
- ECU grounds PASS
- I can trigger Main Relay and Fuel pump and injectors by jumping pins on the ECU connector
- CPS passes OHM test
- Starter input to motronic FAILS - This is pin 27 on the DME connector. According to the ETM This is coming from the OBC relay box - which I don't have. I don't know what this is used for, other than the OBC.
_C
