Okay so I'm new here. I have and 85 325e, I think I've posted once before not much happened in response but still got good feedback. So I got an e30 that wasn't running that fusible link was blown and in tank fuel pump was bad. So I replaced both still got nothing after weeks of frustration I took it to a shop the main fuel pump was bad so got that replaced as well as the main relay. The shop couldn't really figure it out either they were throwing parts at it
So as of then new parts in car
Battery
Fusible link
Fuel pump relay
Main relay
In tank fuel pump
External fuel pump
The cps and speed sensor
Okay so I get it running decent enough well the shop does 😁. I have it running decently for a few weeks so I was like hmmmm suspension and brakes so I replaced pads and rotors and after seeing how bad my suspension looked doing that I ordered coil overs finally got those in, replaced both control arms, control arm bushings, outer tie rods. All said and done just over $1000 in suspension and more than enough else where.
So the day after I get the suspension on I have to drive it to work and halfway there it poops out. And won't start again. So I tow it home and just because I had a fuel filter for it laying around so I replaced it that was a really PITA.
I am getting spark I shocked myself to find out 😂. So I pulled the fuel line off right before the fuel pressure damper and had a buddy crank it and fuel was shooting everywhere so I bypassed the damper thing with some high pressure fuel line and it isn't even coming out of that hose now.
Oh and the main relay is buzzing? I know the icv is supposed to buzz but it's the main relay, if you touch it it vibrates from buzzing. Is this normal?
Oh and I tried a different dme as well
So my trouble shooting thus far is
Both fuel pumps work I ran 12V directly to them.
New fuel filter
Bypassed the fuel pressure damper
I do have spark
Different dme
Charged battery
New alternator(happened because battery wasn't holding a charge not because of this needs a new belt though)
It is cranking and it wants to start but no fuel...
Also yes there is power to the in tank fuel pump
Fusible link =👍
Different fuel pump relay
So questions are
Can I jump my main relay to start by running wires between pins 30, 87, 87a or b?
Why would it give fuel one day by cranking but not the next unless it is a kinked line?
I have another car I just want this thing to be running well😭
Battery
Fusible link
Fuel pump relay
Main relay
In tank fuel pump
External fuel pump
New fuel filter
I do have spark
Different dme
Charged battery
Fusible link =👍
So questions are
