School me on how to correctly adjust e30 throttle position sensor.
  • iwantspeed
    • 3164
    Hey guys. After installing my lightweight flywheel I was trying to increase my idle rpm with no succes.
    In attempting to do that I got my tps out of adjustment.
    Video credit to my wife
    Currently the stomp test does not work but it used too.
    According to Jim leive mastermind e30 motoronic guru
    A car with a bad or improper adjustment of the tps will not get a stomp code
    I have spare throttle body with a idle set screw and tps that has not been messed with and comparing the resistance test values they are different by a lot.
    Old
    New
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • flyboyx
    • 8371
    I'm out on the road so I'm not in a position to look it up for you. Do you have a Bentley? The correct resistance is published there.
    Gigitty Gigitty!!!!
    • iwantspeed
      • 3164
      Thanks.
      I do have a Bentley was not successful in finding a spec in it thou.
      What chapter should I look in.
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • flyboyx
        • 8371
        Hmmmmm... I wish I had it in front of me. I promise you it's there. We used it to troubleshoot my sons drivability problems.
        Gigitty Gigitty!!!!
        • efficient
          • Feb 2012
          • 3312
          Vids don't work. Or maybe it's just my phone
          • iwantspeed
            • 3164
            New throttle body installed on the car with the 0.3 ohms at idle and 0.3 ohms at wot
            And the stomp test is working now!
            Plus 10 hp;)
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • digger
              • Nov 2005
              • 6031
              the ICV looks for a target rpm using a closed loop, i think you need to adjust the chip to get it to work properly. cracking the idle screw doesnt always work that well from a consistancy point of view
              • iwantspeed
                • 3164
                The specs are in the fuel system chapter
                Idle and full throttle switch -29
                Zero resistance at idle and full throttle
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  After Destroying the tps to take it apart
                  I have proved that the old tps was good just out of adjustment.
                  The way it's setup in this video I get zero ohms of resistance at idle and at wide open throttle
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
