ETA Rough Idle When Cold. What gives?
    1985 325e, with ~150K on it. Totally stock. Runs rough on startup, then smooths out when warm. Replaced the coolant temp sensor. Valve Adjustment is next on the list.
    What else could it be?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
    Could be a few things. First thing I would check would be for air leaks.
    1985 325e Sedan, 1986 325e Sedan, 2006 BMW X5, 2012 M3 Sedan, 2013 135is, 2017 M3 Sedan ZCP Competition
      Also check your plug gap. On a 325e, the spec is .028"-.032". A narrow gap can cause a rougher idle as well. If the gap is at the wider range, the idle will be more steady.
      Estoguy
