Hello all,
I have been searching the forums to try to find a car having (or had) a similar symptom to mine.
I have a 325ix that started leaking coolant today. It left a well size puddle, which allowed me to find the location of the leak.
The leak seems dripping from from the underside of the a/c condenser. when I wiggle the condenser, tons of coolant leaks out, but when I position it on its neutral position the leaking stops.
I can't get a good enough look to see if the radiator is simply busted and coolant is coming off of the condenser.
Unfortunately I live in a condo so I can't tear my car apart until I get it into a bay. I am planning to order a radiator as I think it may be the main culprit, but any other thoughts?
I am also planning on removing my a/c condenser as the compressor has already been removed and I have no a/c.
Please let me know if I should be aware of any other items when addressing this leak.
Thanks in advance.
Thanks in advance.
