Hi all, new to E30's....
I have a "Crank, crank, crank, no fuel, no spark no start" issue and have narrowed it down to a bad CPS. (zero resistance)
Trying to trace the wiring, it seems like is tucked in really good behind some hoses/pulleys/belts, what parts do I need to remove to be able to get to the wiring and replace the CPS?
Also, what's the best tool/combination of tools to use to remove the 5mm bolt? I can't get enough torque on my hex wrench and the socket won't get in there/won't get good traction because of the A/C compressor on the way. I'm afraid of stripping it off.
Google hasn't been able to find a DIY for me...is there one somewhere or someone that can list the steps for me? The Bentley just say, "remove from bracket, remove from connector and replace"
1991 325i vert, 125,000 miles
