Identifying Wiring -- Question
  • Lirker
    • Apr 2015
    • 60
    Hey. So a little background. I'm doing an m20 325i whole engine swap into a 1985 325e. I have mostly everything hooked up and ready to go, I'm just confused on what these wires may be.
    Picture 1 - both wires are coming from the fuse box, and are connected; Kind of long in length (One looks like a ground to something, and the other is round female plugs.
    Picture 2 - Both coming from firewall.
    Picture 3 - Both coming from firewall (looks like to starter maybe?)
    Picture 4 - also from firewall, and long in length.
    Thanks for any help!
    Lirker
    '90 325i
    85' 325IE
  • reelizmpro
    • 9558
    The idle control unit is for 84-85 318i, 84-87 325e's only. You don't need that if you're running a 325i engine and electronics.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Lirker
      • Apr 2015
      • 60
      Thanks!
      Anyone else can help me identify the wires?
      Lirker
      '90 325i
      85' 325IE
      • 101
        • Jul 2011
        • 764
        I don't have an E30 in front of me at the moment, but ...
        Picture #1 - do you have your auxiliary fuse box? Those might be feed wires for that. Check and see if they have +12V on them with key off and/or key on. If not, check for continuity with ground.
        Pictures #2,3,4 - Those look like they connect to certain components of the 13 button OBC system - the alarm horn, the temperature sensor, and I forget the third item.
        101
        The E30 collection:
        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
        1987 325is - Delphin / Black Sport (son #3's)
        1987 325i Convertible - Triple Black
        1989 325iX Coupe - Diamondschwarz / Black Comfort
        1990 325iX Coupe - Sterling Silver / Grey Sport
        1981 Fiat 124 Spider 2000 - Green / Tan
        1998 Volvo V70 GLT - White / Tan
        1998 Volvo S70 T5 manual - White / Taupe
        2001 Ford Windstar - Silver / Grey (parts hauler)
        2006 Lexus GX470 - White / Tan (tow rig)
        • peterman
          • Feb 2015
          • 173
          The circular ones look like the go to the outside temp sensor in the driver side brake duct. 13 button obc?
          Sent from my SM-G935V using Tapatalk
          • Lirker
            • Apr 2015
            • 60
            thanks for the help guys. i took my 13 button obc to replace for euro clock so i guess i don't need to worry about that.
            Lirker
            '90 325i
            85' 325IE
