White smoke in engine bay - Transmission?
  • ewolfe57
    • Jun 2016
    • 29
    I replaced and checked all the hoses/connections/etc on my head swapped m20 to see if there was a coolant leak causing the smoking in my engine bay and it's still happening. I drove it real quick bit around the block to get the smoke going and now I'm wondering two things.
    Is it possible to get something in/on an exhaust that would cause persistent smoke?
    Is it possible to have ATF low enough that a transmission would smoke?
    I've got to get to the bottom of this, I can't stand not driving this car!
  • e30davie
    • Apr 2016
    • 1788
    is it coming from the exhaust side?
    I'd guess rocker cover gasket leaking oil onto the exhaust.
    • HerbE30
      • Nov 2015
      • 538
      Very possible. I have seen it happen. Previous post is probably correct. My girlfriends e46 did the same issue. Smoked a lot, it was somewhat intermittent (The only reason it was intermittent was the oil level).
      Check your exhaust manifold, if the heat shield (Flat plate) is spotty. You will need a new valve cover gasket!
      20% Accurate
      Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5599
        My guess is that the valve cover G is leaking on the heat shields.
        • ewolfe57
          • Jun 2016
          • 29
          Man I hope you guys are right! I have an extra gasket lying around so I should be able to check it pretty soon!
          • ewolfe57
            • Jun 2016
            • 29
            I was reading some forums and came across one that described similar symptoms to what I'm having, could white smoke be cause simply by a poorly bled coolant system or air bubbles in the coolant?
            • 5Toes
              • 9836
              it is likely a coolant leak. oil smokes BLUE/dark not white. Only coolant or water based fluids are gonna smoke a whiteish color. Did you check the coolant connection on the back of the cylinder head?
