e30 m20 87325i vert wont start.
  • shoshottz
    • Jun 2016
    • 128
    after doing research through r3v and other e30 sites,ive narrowed my diagnosis down to two components.
    •the cps which i havent tested
    •and the fuel pump.
    tonight im going to test the sensor by replacing it with working one from a friends e30..
    if that doesnt work then the fuel pump
    but quick question.
    a friend who is a mechanic (chevy specialist)
    says the fuel pump should cut on and sound
    like the iac valve
    so i did a quick check and here are the results...
    what do you think?
    iac
    Sorry, we couldn’t find that page
    fuelpump
    help me spend the right 100 dollars!
  • dnguyen1963
    • Nov 2011
    • 2649
    In E30s, the fuel pump turns on briefly when the key is in position two then off. The pump will not run without signal from CPS.
      Not true for an E30. The pump only runs when the DME sees timing data from a rotating engine.
      Later BMWs do prime the pump before cranking.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5541
        Check to see if you're getting any spark.
        • shoshottz
          • Jun 2016
          • 128
          @MrBurgundy after testing ... no there is no spark... what does this mean?
          and is my fuel pump suppose to buzz similar to my fuel pump?
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5541
            If you have no spark, it could be the CPS or the coil itself.
              If you have no spark and the fuel pump isn't running, the likely suspects are (in order):
              a) Bad main relay
              b) Bad CPS
              c) Bad fusible link in the small cable from the battery positive
              d) Bad DME ground
              e) Bad DME
              f) Bad engine harness
              There are other more rare possibilities, but start with the above first.
              • Cayoncrusier93
                • Jan 2013
                • 204
                Start by checking your fuses, I replaced a fuel pump in my E30 when it was only the fuse. The old open top fuses sometime burn out at the solder point on the edges and not necessarily in the center wire like new fuses, that's what tricked me when I looked at them.
                And like others said, fuel pump is only ON when engine is cranking.
                • shoshottz
                  • Jun 2016
                  • 128
                  SOLVED!
                  •CPS Installed!
                  thanks gentlemen.
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5541
                    Nioce
                    • shoshottz
                      • Jun 2016
                      • 128
                      yeah gonna update all of them with new ones when i work on my car again next.
