sounds like its better to test out the btb copies
Which header would you use..?
Originally posted by squidmaster View PostYikes! I'm sorry I didn't notice that they were for the e21. I saw the hp gain mention but just through it was a reference. Might be an excuse to install an oil relocation kit? Maybe a better cooler if you plan to build the engine for track?
Originally posted by digger View Postsounds like its better to test out the btb copies
Ok, some progress. After more detailed look I have decided to use Hartge headers anyway. After some measurements I had to cut the flange off, and cut the primaries for about 10mm and welded the flange back. Now the problematic header sits 4mm close to the strut tower. It was not so bad as I thought it was. Will post photo when in position.
I also found solution about oil filter on e30.de. If you rotate it for 180 there is no problem at all, even with ac compressor-and it is also much easier to change it when servicing I think :).
Photo of original e30 hartge header versus e21 Rallye header, e21 header is much longer...
