Fuel pump not starting when engine is hot
  • harold30
    • Jul 2011
    • 180
    Hi Guys,
    I have this problem with my car lately when then engine is hot, it will just crank but won't start. What I always do is removed the fuel pump relay and cool it down, put it back again and starts right up. I tried switching with different relay but same thing happen so the relay is not the issue but somewhere else. Could it be a contact or wiring problem? or other else? Can someone point me where to look first.
    Cheers,
    Harold
  • superj
    • Feb 2006
    • 397
    like, if you remove the relay and put a spare one in, the car starts immediately? have you tried that or just pulled the relay and let it sit so everything cools off the same?
    that's definitely odd.
    • harold30
      • Jul 2011
      • 180
      removed the relay and rubbed it with my palms to absorb the heat, after a minute or 2 put it back on and it will start, though most of the time a weak start but still better than just cranking.
      no i haven't tried replacing it with a spare one but instead switching relays from fusebox but since it's warm it won't start.
      • Kershaw
        • 11822
        Have you tried just waiting a minute or two? Have you verified that your relay rubbing technique is what is causing the car to start?
        AWD > RWD
        • harold30
          • Jul 2011
          • 180
          I tried waiting 5-10 minutes without opening the hood and it won't start. that's why I always rub the relay to make it start right away. I also tried switching the fuel pump relay with o2 sensor relay without rubbing and they're still warm and it won't start.
          BTW, I came from a country where it's hot and humid through out the year so the engine won't cool down right away. (IDK if it matters though)
          Maybe I just too focus on the relay where the problem lay somewhere.
          • dnguyen1963
            • Nov 2011
            • 2651
            If the relay gets that hot then it is drawing way too much current. Check for short in the wire between the relay and the pump.
            • Seawolf
              • Feb 2015
              • 270
              This could be caused by other things but it's easy enough to eliminate the fuel pump relay.
              Make up a short jumper wire with a 1/4" male spade connector on each end, or use a paper clip if you really have to.
              Next time the car quits pull the fuel pump relay and use the jumper to connect pins 30 & 87 on the relay socket, this will effectively bypass the relay.
              If the car starts then the relay is the problem, if not then the problem is something else.
              • harold30
                • Jul 2011
                • 180
                I always suspected a short somewhere in the wires. Will check it when I have time. Thanks!
                • harold30
                  • Jul 2011
                  • 180
                  I'll note and do this next time. Thanks!
