M20 Lightweight/ Low inertia Alternator...
  • AntParker
    • Jan 2017
    • 32
    Hi Guys,
    Probably need to replace the alternator on my track car this weekend- already running lightweight Varley battery etc. but if I'm going to replace the alternator anyway i would rather upgrade, Just wondering if you guys have any recommendations on lightweight alternators which i could upgrade to at the same time?
    I Do have a couple of motorcycle ones here, but they will need pulleys making up etc and i don't currently have the time.
    Just wondering if there is something off the shelf, or nearly off the shelf i can bolt on?
    Thanks in advance!
    Ant
  • TobyB
    • 5298
    Not bolt, but the smallest ND alternator's really small, pretty light, and low- inertia.
    It's what you see on Nascarr stuff- for $250. At the pull-a-part, I get them from Chevy Sprints for the 2002,
    and Subaru Justys for the tii- mounted version. They're up to $25, but I always steal the connectors and brackets, too, as it's a head- start on making your own.
    I have found them to be very durable in track use on the M10, and they're good for 50 amps. Reliably. A larger pulley doesn't seem to affect idle voltage too much, either.
    But you'd have to splice and make a bracket.
    fwiw,
    t
    • AntParker
      • Jan 2017
      • 32
      Thanks Toby, looks great, Will definitely try and get my hands on one of these.
