Hi all,
I've been trying to get my coolant light to shut off, but it just doesn't want to.
First, I checked that the coolant level was correct. That wasn't the issue.
I installed a new coolant level sensor, which was fully functional before I installed it. That didn't solve the problem.
I checked the pigtail connector for power, which read 12 Volts on my multimeter, that wasn't the issue.
I checked the coolant level sensor for continuity, which it has, so that isn't the issue.
What do you all think I should do?
Thanks!
Thanks!
