No crank
  • mazzo
    • Jul 2014
    • 264
    No crank
    Hi all,
    My car was sitting in garage for the last 2 months. Today when I try to turn it there is no crank. The battery has lower, but I did not hear any noise from starter. I would like to know how should I check it. I plan to check the fuel relay (just in case) . What else should I check too? Thanks for ur advise.
    Matthew
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • TobyB
    • 5287
    Buy an inexpensive voltmeter.
    Meter the battery.
    Then charge the battery, at least overnight.
    Then meter the battery again,
    and again, while cranking.
    After sitting for weeks, you can see as low as 12.6 volts on a 'charged' battery.
    After charging, you should see 13.5 or so.
    Running, 14.3 is good.
    To get you started...
    t
    • mr.vang
      • 4371
      Battery is weak. It won't have enough juice to kick start the starter.
      • mazzo
        • Jul 2014
        • 264
        Thanks!
        Yes, I was naive to believe that my battery is in good health when in fact it has only 12.1 volt. Thanks.
        Current:
        Past:
        '06 325i Black 5sp
