e to i swap
You can put an I harness and computer on an e. But you have to get all the sensors and parts that the I uses in order for it to work. You cant use e sensors anymore, and the I takes crank readings from a sensor off the front of the motor which you need, etc.. there are some other threads about it if you search around.Old and improved:
thanks for the infoComment
