NEED HELP! 85 325e won't start! No spark from the coil!
  • Purist Form
    • Sep 2015
    • 39
    Hey everyone I'm need of some help! The other day my 325e would not start at all. It cranks over perfectly it's getting fuel but no spark. I've replaced distributior cap, Rotor, ignition coil, spark plug cables, crank position sensor and still nothing. I've checked the main relay switch and fuel pump relay and they both work fine. But still no spark
  • Kershaw
    • 11822
    Have you checked your fuses? Is your ignition coil properly grounded? Is your engine ground good?
    AWD > RWD
    • ChrisM
      • 1276
      ecu
      93 E30 325ic BrilliantRot M20B25 TCD S2+ GS637BZ CT3582R MS2
      Bought from or sold to me?
      http://www.r3vlimited.com/board/showthread.php?t=200290
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5591
        ecu probably took a fat dump, or you have a shit ground somewhere. Do you have juice going to the coil?
        • flyboyx
          • 8371
          Look at your crank shaft sensor wire where it runs behind the water pump pulley. There are supposed to be two little clips that hold this wire to the timing cover. They often get broken during a timing belt job. The wire then rubs against the back of the pulley causing it to wear through the insulation.
          Gigitty Gigitty!!!!
          • Purist Form
            • Sep 2015
            • 39
            My fuses are good. The crank sensor is in good shape as well but my ground cables do look a little worn so that could be an issue I'll definitely check that but I'm trying to source a ecu to test as well
            • Purist Form
              • Sep 2015
              • 39
              I'm also getting power to the ignition coil side terminals but nothing out of the center main lead
              • YosemiteSam
                • Apr 2011
                • 1303
                Check the ground side of the coil while cranking and your battery voltage while cranking. If those two numbers are the same, then either your ECU is bad or the wire in between the ECU and the coil is bad.
                • Purist Form
                  • Sep 2015
                  • 39
                  If that's that's the case then my ecu might be bad then since I'm getting the same voltage on both sides and the coil is brand new
                  • YosemiteSam
                    • Apr 2011
                    • 1303
                    That has to be while cranking, that test tells you nothing if you just have the key on and the engine off.
                    • Purist Form
                      • Sep 2015
                      • 39
                      I didnt test that while cranking so I'll have to check tomorrow.
                      • c0rbin9
                        • Dec 2015
                        • 609
                        This is all you need:
                        1991 318is Brillantrot daily driver (slow restoration)
                        • Pdxseth
                          • May 2012
                          • 3124
                          There's two "crank sensors"
                          On an eta you have a sped and reference sensor, check them both, if they are good it could be a flywheels issue causing a poor reading.
                          Sent from my iPhone using Tapatalk Pro
