Engine noises after 6months of not running
  • DaWildBeast
    • Mar 2016
    • 244
    Hello i crashed my car about 6 months ago i just got everything installed engine wise and i turned ot on! But it was making horrible noises any help is appreciated.https://youtu.be/Fhcc09p2v_A
    Sent from my SM-G920V using Tapatalk
  • dnguyen1963
    • Nov 2011
    • 2651
    The belts are rubbing against something...
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5611
      The belts or fan are rubbing up on something.
      If you reinstalled the same ps pump, ac, alternator and water pump, make sure all the pulleys are spinning freely and wobble free.
      • DaWildBeast
        • Mar 2016
        • 244
        Okay so i went outside to check on that... and now it wont start :/ https://youtu.be/KERqSPd-LHg
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5611
          You need to see what you're missing. gas, spark or compression.
          edit, did you recently do the tbelt?
          • DaWildBeast
            • Mar 2016
            • 244
            Haven't done anything to the timing belt. Im just considering it was rubbing on something but couldnt find out.
            • DaWildBeast
              • Mar 2016
              • 244
              Could my gas have gone bad? 6 months of sitting may be the reason its not starting now? I think im going to check that tomorrow
              • Kershaw
                • 11822
                I've seen m20s and m30s start up on 4 year old gas before. Nothing's happening in 6 months.
                AWD > RWD
