My oil return pipe is leaking?
  • schnitzer325
    • 1
    There is oil leaking out of the oil ruturn pipe that goes from the intake manifold to the block. Can I tighten this pipe by or how can I fix this? My car won't idle and I checked the fault codes and came up with 1222. I probably have some vacuum leaks that I need to take care of, but my main concern right now is the oil leak.
  • EtaSport
    • 2853
    Sounds like you'll probably need two new o-rings for that tube. also make sure the spring is installed on the bottom.
    Old and improved:
    • digger
      • Nov 2005
      • 6207
      it sounds like its actually the the crankcase vent rather than a oil return pipe. There should be some seals to replace as Etasport says
