Need help! Sputter/Misfire 325E
  • iamkorruption
    • Feb 2017
    • 9
    My 1985 325E is giving me a hard time lately. Ran perfect until I took it to the car wash the other day then started my misfire or sputter at idle and when giving it throttle. If you are very light on throttle it goes up in RPM but any more than a touch it sputters like crazy and will not accelerate. I am also now having a problem that when flooring gas pedal (and only when flooring) after a few seconds the car will just stop responding to throttle and give up then come back as soon as i let up and give it any less than full throttle.
    Smoke tested found no vacuum leaks. Injectors cleaned and flow tested. Fuel pressure is good. Timing is in spec. Valves adjusted.
    New parts - Alternator, coolant sensors, plugs, wires, ignition coil, idle control module, idle control valve, DME, distributor rotor and cap, transfer pump, main fuel pump, valve cover gasket.
    Need help on where to go from here.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5574
    c
    p
    s
    b
    r
    o
    • wilholl
      • May 2012
      • 518
      Some thing to consider:
      Check for water in the O2 sensor connector and water in the injector harness connector where it connects to the engine harness (driver side of the block, under the intake manifold.
      Water likes to collect in these connectors and makes the engine run terrible.
      This is based on my personal experience...
      1988 325 non-letter Seta "Bronzit"
      1991 325ic "Laguna Green" (Sold)
      1993 325i "Laguna Green/Silver" (Sold)
      1998 528i "Artic Silver" m-sport(totalled by drunk driver)
      2000 528i Titansilber/gray m-sport
      2000 528i Titansilber/black m-sport(sold)
      2001 525i Anthracite m-sport(sold)
      2013 750i Black/Black m-sport "Beast"
      • iamkorruption
        • Feb 2017
        • 9
        Sorry crank position sensor and flywheel reference were also replaced and tested after replacement. No water in 02 sensor connectors and unplugging them doesn't change anything. Where is the injector harness connector? I have looked under the intake manifold and cannot find anything.
        • EyExR
          • Jan 2011
          • 959
          It's called a C191 connector. You can see how it comes off the injector harness here:
          Feel around under the intake. It's there. Or remove your AFM and airbox to get a better grab at it.
          If that doesn't solve your problem I would also test a spare AFM if you can.
          My 325iX DIY Threads:
          Front Wheel Bearing Replacement
          325iX Rear Subframe Bushings and MUCH more w/pics!
          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
          • iamkorruption
            • Feb 2017
            • 9
            I have a brand new AFM installed in there and it tests fine. My car does not have that connector underneath. Is there a chance the 325e doesnt have it?
            • iamkorruption
              • Feb 2017
              • 9
              Still havent found the problem. Have tested multiple wires and sensors for a while now.
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5574
                check the ring on the harmonic balancer. maybe the cps is having a hard time reading the crank position
                • iamkorruption
                  • Feb 2017
                  • 9
                  My crank sensor is in the bellhousing and all teeth in there are intact.
                  • EyExR
                    • Jan 2011
                    • 959
                    Whoops! Sorry bud you're right. You have a Motronic 1.0 system. No C191
                    Where did you get your new AFM from? BMW? I'm VERY suspicious of rebuilt ones depending on where they're coming from. I'm not sure if the connectors are the same or what but I do know the AFM has to be specific to your engine. In your case a M20B27.
                    • iamkorruption
                      • Feb 2017
                      • 9
                      Brand new oem afm. Any other suggestions/ideas?
                      • EyExR
                        • Jan 2011
                        • 959
                        Throttle position switch?
                        • iamkorruption
                          • Feb 2017
                          • 9
                          Throttle position switch new as well and tested/adjusted just in case.
                          • Kershaw
                            • 11822
                            Fuel pressure regulator.
                            And / or
                            fuel filter
                            fuel pump(s)
                            I found several times that the scenario you describe to be caused by fuel issues, not electrical issues. And you seem to have covered the electrical said in any case.
                            AWD > RWD
                            • EyExR
                              • Jan 2011
                              • 959
                              Grasping at straws. Could it be your airbox got flooded?
