Conrod bolt question
  • joecrotch
    • Dec 2008
    • 117
    So I am going to ask a question I already know the answer to just because.
    I "was" freshening up my motor since I am slapping in a bunch of new parts and had it out already. My plan was to do everything except removing the rotating assembly. While on a roll removing parts I started breaking bolts loose and realized I had just loosened the main cap bolts.
    Like I said I know the answer but just making sure. I assume I was not over zealous in ordering all new bottom end hardware this morning. They will need to be replaced correct? I assume there is not some magic 5 second rule or something if I tightened them back up super quick lmao.
    That wonderful feeling you get when your project budget just doubled again......
  • digger
    • Nov 2005
    • 6194
    conrod bolt or main cap bolt? thread title doesn't match.
    M10 mains cap bolts you wont have any issues reusing they arent stretching at 60Nm
    M8 rod bolts id buy another one as they are "stretch" bolts though some do reuse them
    • joecrotch
      • Dec 2008
      • 117
      Sorry yes I am talking about the mains cap bolts. I had already purchased new connecting rod bolts since I am doing the rings.
      Thank you that clears it up a bunch!!!
