This is my problem, it feels just like it looks there where the power comes in a rhythmic pattern?
I have done the following:
Reman Bosch AFM
Bosch O2 sensor
Dist cap and rotor
Fuel filter
Fuel pressure regulator
Fuel psi runs between 35-40 and I'd like to see it higher
Timing belt
Water pump
Fan clutch
Coil tests at 4.5 ohms, Bentley says 3.5 if I remember right
Plugs check ok but I'm getting new ones tomorrow.
Tps switch works for idle, I can't get wot signal out of it, I haven't ordered one yet.
There are a few more un related things I've done to the car
I'm getting frustrated, the engine runs better than it did when I got it but it still won't give me the I6 power I crave. I know it's not an i car but it's got to give smooth power.
Any help is appreciated
Reman Bosch AFM
Bosch O2 sensor
Dist cap and rotor
Fuel filter
Timing belt
Water pump
Fan clutch
