87' 325e died while in gear turns over but wont start
  • grimm
    • Mar 2016
    • 13
    Hello, this is my first post. I have managed to find just about all the answers to all of the other fun problems in prior threads but im coming up short on my current issue. I drive a 1987 325e sedan with a March birthday.
    Heres the deal, this started maybe 3 months ago I noticed a loss of power during acceleration it feels more like when you are learning to drive a manual and haven't quite nailed down your clutch to gas rhythm. The car is kind of sputters acts as if its going to stall out then acts as if nothing is wrong, there is also no real rhyme or reason to it whether the engine is hot or cold, if the temperature outside is hot, cold, dry, or wet. Sometimes ill have a month where it wont happen or a day where it acts up every time I accelerate. Only twice has this sputtering killed the engine while driving and in gear, i was able to turn the key and fire it right back up as if nothing had happened. Now the 3rd time was the charm, I was of course in 3rd gear it sputtered and died, this time it will not fire back up. If i turn the key It turns over it has spark and fuel it just wont start. I can hear the fuel pump going, I replaced the crankshaft sensor today with no avail. am at the point where I think it might be a ground???? Im stumped any hints as to what going on would be much appreciated.
  • Todd Black 88
    • Oct 2007
    • 3449
    Take the oil filler cap off and have someone turn the car over. See if the cam is turning
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • grimm
      • Mar 2016
      • 13
      Ill give it a shot, is there something specific i should be looking for? if there's no cam motion what would that lead to?
      • Bimmerboy91
        • Feb 2007
        • 622
        No cam movement means your timing belt broke, with a good possibility that some valves are bent.
        If that's good I would check your AFM to see if the flap isn't stuck or something.
        • grimm
          • Mar 2016
          • 13
          Alright, so pulled the oil filler cap the cam shaft is moving. Ive got fuel and spark. looked at the AFM and its not open or stuck.... oui vey! is there anything else that could be causing this. I just went through and cleaned all my grounds as well. Could the ECM or is there another computer somewhere that could be causing this?
          • grimm
            • Mar 2016
            • 13
            Anybody got anything?
            • ahlem
              • 369
              When you say you've got fuel, what do you mean?
              Did you do a fuel pressure test? If you have some fuel you may not have enough pressure to push fuel through the injectors. A soon to die fuel pump could cause the problem. How old is your fuel filter? I'd tee in a fuel pressure gauge to your fuel line and see how many PSI you have. Also pull the vacuum hose frome your Fuel Pressure regulator to see if any fuel is getting past a bad regulator.
              • grimm
                • Mar 2016
                • 13
                I have fuel pressure, I just changed the in line pump and fuel filter did the test and all of that. Did not change the pump in the tank but I can hear in ticking away in there and the pressure is fine. The new issue i'm finding is the spark. I just put a new battery in the car, changed the wires, distributor cap and rotor less than 1 year ago. When i do the electric test i have power all the way to the coil and from the coil to the distributor cap but from there I am getting no spark at the plugs? the distributor cap and rotor look fine on a visual inspection no crack or carbon deposits there is a little pitting in the tips but nothing absurd.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Seems to be the season for eta tough starting. In my case it was a no warm start. Was fine hot or cold. Turned out to be the cps which is on the trans housing not the crank, so not sure which you replaced.
                  Alice the Time Capsule
                  • Das Delfin
                    • Sep 2014
                    • 2293
                    I was going to say crank position sensor
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      It's actually an FPS on an eta :)
                      • grimm
                        • Mar 2016
                        • 13
                        I went ahead and replaced the CPS down on the bell housing but that didn't seem to change anything. Im gonna try finding a Motronic ECU to see if that does the trick. One other suspect might be the coil but when I ran the Bentley test it read .5 ohms on the 1-15, and was reading 3k ohms on 1-4 I believe it should read at 5k If it were over 5k then it would be bad, correct? if that is correct then im assuming it would have to be the ECU?
                        • Blamfam
                          • Jun 2017
                          • 26
                          Mine Too...
                          I have an 86 325e and mine just started doing something similar, with a little pattern.
                          Mine seems to stall out at about 1500 rpm, mostly in second. But I spend a lot of time in second, so there's that...
                          It only dies once in awhile with the clutch in.
