Bringing this m20 back to life
  • mbonanni
    • Sep 2011
    • 6236
    I recently picked up a 1991 325i that had been sitting for 10 years. Things I have done or have checked to get her to this current point.
    New Spark Plugs (good bosch ones)
    New fuel (most of the old stuff had been emptied before storing)
    New used fuel pump
    Getting spark in all 6 cylinders
    Getting fuel from injectors in all 6 cylinders
    Timing belt
    Waterpump
    Tensioner
    Oil change
    New Chassis ground cable
    New Battery
    I checked for spark and fuel in each cylinder and they all checked out individually. I believe I am getting the misfire in cylinders 2, 4, and 6. I tried swapping plugs from cylinder 1 & 2 thinking it was the plugs had fouled (visually one looks black and fouled), but it still missed in 2. I also switched the wires from cylinders 1 and 2 and they neither fired, not sure if that means anything given the different timing.
    I did just do the timing belt, could this possibly be a culprit? Maybe I was off by a tooth? Excuse the lil vacuum sound in the video, while I was removing the valve cover earlier I broke the line /: Could this be the culprit? It was running rough before I broke it...
    Here is a clicky link while I try to figure out how to embed correctly
  • YosemiteSam
    • Apr 2011
    • 1303
    How sure are you that you are getting fuel from all the injectors? 2,4, and 6 all share a single injector drive. If the PCM were not sending out the signal for that bank, or the wire were cut/broken/corroded/etc those three injectors would not fire.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5599
      I'd start off by fixing the vac leaks.
      Is it a dead miss or does the engine react to each ignition wire being removed?
      • mbonanni
        • Sep 2011
        • 6236
        I removed the rail from the head, put paper undr each injector then cranked over several times. each piece of paper was wet with fuel when I checked them.
        I will get to that soon, however right before this video I broke it and it ran identical, which is why I decided to still post it. I'll run to the parts store later and pickup some tubing.
        Also, not exactly sure what a dead imiss is vs what youre describing is, but I showed in the video that removing plug wire 1 the engine runs rough, removing 2 it doesn't run rough, and so on for the respective cylinders.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5599
          That's a dead miss. I didn't know you pulled the wires in the vid. I just watched the whole thing.
          Have you done a compression test?
          • mbonanni
            • Sep 2011
            • 6236
            I have not got the chance to do a compression test, but if I happened to mess the timing up when doing the timing belt recently then those cylinders wouldn't read correctly if I checked for compression, correct?
            I may just tear into the timing later today when it isn't so damn hot and check again to see if my marks line up. If I was off a tooth would it cause a miss in three cylinders? Perhaps stuck valves or something of the sort?? The motor has been sitting for 10 years.
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5599
              I doubt its the timing because the other three cylinders are firing. If the timing was off, it would effect all the cylinders.
              And yes, if the timing was off, it would show on all the cylinders in a compression test.
              Also, check the distributor cap and rotor.
              • YosemiteSam
                • Apr 2011
                • 1303
                Interesting. In that case, how did you check for spark?
                • mbonanni
                  • Sep 2011
                  • 6236
                  Disconnected fuel pump, removed each plug individually and watched to see if there was spark while I cranked it over. I believe 2/6 plugs were black. Cant remember which ones but will check and get back.
                  • YosemiteSam
                    • Apr 2011
                    • 1303
                    This is not a good way to check for spark. Get yourself one of these: https://www.amazon.com/OTC-6589-Elec...s=spark+tester (you can unscrew the thing on top so they work with E30 wires) and check spark that way. If you just have the spark plug on the end of the wire you don't have nearly enough resistance to see if it will spark while cranking/running. Added bonus to these tools is that they make a nice crisp snap when it sparks so you can see as well as hear the spark.
                    • mbonanni
                      • Sep 2011
                      • 6236
                      Bringing this m20 back to life *misfire*
                      I'm interested, but regardless if there is enough resistance or not there was spark from plugs 1-6 using my method, so I know Im getting spark. Would it change anything if I said I held them close to the engine hook/body/valve cover so I could get a larger gap? Essentially more resistance, yes?
                      Just to clear it up are you're saying when the plugs are installed and the car is running there is potentially more resistance in the wires (Or plug?) which can result in no spark? So this lil guy simulates the car being under load which is why it would give me more accurate results for the spark? Essentially if I got no spark while using this tester It would mean either bad dist cap, rotor, or ignition coil. Is this correct?
                      • YosemiteSam
                        • Apr 2011
                        • 1303
                        Precicely. If you hold the plug ~1/2" from the block and it still jumps that then you are probably good. Just be careful, if you are touching the body of the car or the engine block you are liable to get shocked. It's not dangerous, but it will make you jump. I was once doing something similar and the only part of my body I dodn't notice was too close to the car was my junk, that one hurt a lot.
                        • HerbE30
                          • Nov 2015
                          • 538
                          Have you check your distributor and rotor button? Pop it off and check for any corrosion. It was the cause of my issues, took a while to trace it down.
                          20% Accurate
                          Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
                          • mbonanni
                            • Sep 2011
                            • 6236
                            Awesome, thanks guys. I'm out in Vegas for a little vacation so once I get back I'll make sure to order up one of those spark testers and peep the condition of the cap and rotor.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Being a late model, you probably have the round injector harness connector under the TB/manifold. That connector has a habit of corroding and kills half the injectors, or messes with the coolant temp sensor (in that same plug).
                              In that plug, there's a temp gauge wire, temp sensor wire(s), a ground for each injector (ECU grounds injector to energize, they are always hot), and two battery positive - one for each bank - ie injectors 2,4,6 and 1,3,5. With m20 having a distributor, one whole bank is unlikely to have ignition as the culprit.
                              john@m20guru.com
                              Links:
